Biscuit Tin Lid
Started by sasa1000, May 30, 2010, 09:25:13 AM
sasa1000
Just wondering if sitting supplied antenna on biscuit tin lid in same position as without will be of much benefit. Will I see an increase in range or better coverage? Just asking as I am new to all this and realise there are a lot of people on here who are very knowledgeable on the subject. If it will make a difference, I will try it later on if I get a chance. Just experimenting before siting outside.
Sandy
Deadcalm
Before I invested in an external antenna, the biscuit tin lid concept of a ground plane worked for me - I found it made quite a difference.  It also gave the supplied antenna (which has a tiny base) some stability.  Still use the lid if I use my RB in the garden, with the laptop.
DC
g0seg
Just a point in passing. Yes, an increased area groundplane does help. I suggest you get a teflon covered cake tin about a foot in diameter so you get more area and no corrosion! Bi now, Roger
sasa1000
Thanks guys, that's what I needed to know. Now just to get the wife to look the other way while I acquire the lid off the biscuit tin.
Sandy
viking9
Quote from: sasa1000 on May 30, 2010, 01:49:02 PM
Sandy
Or you could buy her a tin of Cadbury's Roses or Quality Street. :o)
Tom
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
sasa1000
That's a good idea Tom, but slightly flawed as I would probably eat the sweets myself (Well the good ones) Thrown out hundreds of tins over the years too!
Sandy
Paulc
May have to resort to a tin lid as my baseplate has gone awol unless I can buy another one from somewhere - any suggestions?
MW0CVW
Blast from the past, the old Biscuit tin lid as a ground plane.
not very good back in the CB/27/81 days.
But a better ground plane at 1090 Mhz
cos the waves are much shorter!.
