Using the Quick Filter
Started by grasscutter, June 26, 2010, 10:58:41 PM
grasscutter
I have been using the quick filter to identify the whereabouts of an aircraft. After selecting "registration" from the drop down menu, then = then the aircrafts registration from the DD menu, then after clicking on "filter" should the map then move to the location of the aircraft in question. Mine isn't and have to go searching for it ie aircraft with a circle round it Is this normal, and then to clear it do you click on "show all".
The filter is just for the MyFlights section, you then double click on the row in the MyFlights list and it should centre the aircraft.
grasscutter
Hi GC, also if you're following a particular aircraft, double click on its symbol and that will also centre the display on that aircraft.
