"Hardware: Not Connected"
Started by dca, August 02, 2010, 01:51:10 PM
dca
Can anyone offer any possible reasons for this please. The hardware IS connected, in fact it hasn't been dsisconnected for around 4 months and was working fine last night. Today I turn on the PC and have a red box and the statement Hardware: Not Connected. The USB light is flashing blue at a rate of 1/sec.
I have previously had to send my box back to W&S twice (in 20 months) to have the saw filter replaced. Could it be this again? It get expensive sending back at own cost.
I have sent a note to support but no answer yet (it was around 5 hours ago)
Thanks,
Dave
9 nm south of LGW
Dave
Unplug the USB link and then plug in back in and see what happens.
As far as support goes remember they are 8 or 9 hours behind us.
dca
Thanks Alan,
I tried that earlier and had the same result. I also tried it in other USB ports with he same outcome. It isn't the USB ports as I've tried other equipment in them and they work fine.
However! I have just tried the box in my laptop & it works and therefore deepens the mystery?
I'm runnning 64 bit vista on the PC and XP on the laptop.
Help!
9 nm south of LGW
Hi dca,
Couple of items to check
1) Check your machine didn't update windows last night, some updates have a habit of causing something weird to happen, your drivers might have gone and need installing again.
2.) Check the USB cable is ok, try another.
3.) Are you using an USB hub, if so did you connect anything else which might be taking all the power from RB.
dca
Update...
I looked to see if the drivers were still ok and the USB was not recognised.
I unplugged, rebooted the PC & now its working again- bizarre!
9 nm south of LGW
rashers
hi i had the same problem they kept telling me drvers wasnt it was the usb connection at the back of my radarbox was faulty sent it back to waters stanton quick turnaround sorted it its working fine again try that believe me it will work
LSZS
Hello, I've the same problem since june when I updated to version 3.13.
I've win xp.
To solve this problem i must close and re-open the program
Engadin Airport auf 1707m / 5600ft. Europas höchstgelegener Flughafen
http://www.flickr.com/photos/stefanobazzi/
krharris
hi any one out their that can give me some direction. I have just purchaced a new laptop and it has windows 7.Power light is on but no flashing l.e.ds  It works fine on vista so i know that the unit is working ok.do i need 64bit down loaded or do i require a new cd-rom for windows 7.
                   krharris
dca
Basic I know but have you tried unplugging & rebooting? It worked for me!
Dave
9 nm south of LGW
krharris, if you have not done so I would suggest that you go to http://www.airnavsystems.com/RadarBox/support.html and download the latest drivers.
