New box problems
Started by meder, October 13, 2010, 01:51:09 PM
meder
Just purchased a new radarbax and trying to set it up.and unable to start sofware
Problem is when software starts it shows a popup asking you to enter your details,Place name etc.
have entered details but it appears that half the popup is missing, only shows half of name boxes and the bottom stops half way across the long and lat boxes.
Have tried expanding box pressing enter etc to no avail.
Have tried install on my laptop also and it is the same.
I have also downloaded latest software and still no joy
I must be missing something
meder
Thanks for reply Tarbat
Have tried imputing in demo mode but same problem only half the popup appears.
so I have no apply button.
Seem to have drivers in OK
This is due to either a non native resolution or a small screen (netbook).
Try the following:
1) Increase your resoultion
2.) Decrease your font size
3.) If you have a netbook some allow you to scroll down further in the screen view
meder
It is not a netbook its a full pc,the main screen under the popup is ok it is just the preferances popup thats the problem ,Running res at 1680x1050 and small font and there are no scroll bars in the popup and it will not allow me to enlarge the box so stuck
thanks for help
meder
tried resize enable thanks did not work but!!
Found a work around  ckick on forum button to position curser press tab enter 10 times and the popup dissapeares and it stores  data
thanks for help
meder
Wow got software in and thought problems are now over but I was wrong
I only have the power led lit no usb or signal software shows. Box is showing in control panel and working.
have changed usb cable reinstalled drivers but still nothing
hardware says checking with a yellow icon, network also says checking with a yellow icon
Is box faulty?
Restart your machine and try starting it again.
meder
#9
Hi Thanks to all who helped I am now up and running.
My box came with 2009 software and the drivers don't seem to work with win 7 64 bit. I had loaded the 2009 and then did the 2010 upgrade with no joy. I had uninstalled and reinstalled on several occasions to no avail.
I downloaded and used a third party uninstaller and did a deep uninstall, reloaded driver and software and like magic it worked.
have to save up now for D and external Ariel
Thank again
