Airnav and airports departure / arrival indications
Started by sth39, December 12, 2010, 08:52:21 PM
sth39
Hello,
I am new with Airnav 4.03 version, and i have 2 questions :
1/ How to proceed to have departure and arrival airports on main screen board ?
2/ Is it possible to have airports name instead of airport code ?
Many thanks.
What do you mean by the "main screen board".  If you mean the list of aircraft (MyFlights), then select the Routes column in preferences.
To see the airport name, click on the aircraft and the departure/arrival airport names will appear in the aircraft details window.
sth39
It'ok for Routes column.
But, is it possible to have Airport names instead of airport number ?
For example : I need to see Las vegas instead of LAS.
There is no suite forum. Please contact support from the contact method instead.
