Map colurs
Started by anodes, January 20, 2011, 07:04:49 AM
anodes
Hi all, has anyone experienced the problem of the air name colour going back to a default colour after switching the pc off, done all the usual things, apply, OK etc.
Thanks in advance Stephen
Hi Stephen
Once you have set your colours on the Preferences screen, you need to Export the scheme as Real Radar. Also Export it as Default to be on the safe side.
The program loads one or the other at startup ...dont ask ;-)
anodes
Hi Rod, thank you for your help - spot on, have done as you suggested, yet another fix.
Stephen
