ANRB start up program
Started by theastra, December 24, 2010, 07:53:31 PM
theastra
Hi, I hope somebody can shed some light on this. This morning, I had ANRB attached to the PC it normally runs with, and it was working fine. I disconnected the box and used it with a laptop (netbook) for a couple of hours. I subsequently re-attached the box to the primary PC, launched the program, and got as far as 'loading nav data' and then the program stopped responding. This happened 4 times before the program finally ran thru the entire startup sequence and launched. Now it is working fine. During all these failed starts, I re-booted the PC a couple of times, checked the USB cable, etc. I also hooked the box back up before turning on the PC.
I'm running windows 7 on the primary computer & XP on the laptop.
Thanks in advance for any insight.
Steven
P.S. It just stopped working. I re-launched, and the start-up took about 4 minutes? The start-up almost always takes ages...how come?
dudbaker
Steven
To speed up the start go to Mylog/Tools and delete old data.  This will delete flight data but not aircraft data.
Dudley
Dudley Baker
Stansted
G8THH
