Web Enabling RB
Started by CZUL, January 08, 2011, 09:24:37 PM
CZUL
If this has been asked and answered already please accept my apologies.
I would like to know if RB can be web enabled? I would like to create a site on a home intranet in order to see the application from any pc on my home network.
Paul
Hi CZUL,
RB allows you send a screenshot of the map every minute, so you can set it up to upload a screenshot to your intranet site.
Though what might be easier is to use remote desktop connection or other similar tools to connect to your machine that has the RB on it from other machines in your intranet and then you can view the software as if your logged into that machine.
CZUL
Yea I have been doing that. There are a few issues with RDP related to screen res having to be adjusted. I was hoping for a web solution so I could have more flexibility.
DaveG
If you just want to view/control RB from any PC on your network, try Logmein Free.
Cornwall, UK
G8VXY
It would be nice for a version with an Ethernet port instead of a USB and possibly a in-built SD card to save data, this would allow for many options like running a RB and sharing the data that will operate all the time without having to leave ones PC switched one, could also work from a location closer to the mast saving on running costly cables.
