Lightning protector
Started by Dana, January 25, 2011, 12:10:10 PM
Dana
Hi ,
Can someone tell me if this lightning protector is good for my RB ?
http://cbradios4u.co.uk/SHARMAN-S-SP-35R-LIGHTNING-SURGE-PROTECTOR-CA-35R.2.html
I am using a BS1105 antenna without amplifier.
Or can someone tell me what other electrostatic protector to use to groung my external antenna?
Thank you very much !
chewycanes
I may be wrong and may be corrected by someone else but the problem with Lightning protectors is that the voltage at which they trip is greater than the input to the airnav box can withstand. Therefore should you get a strike it will still damage your box before the protector cuts in.
The best protection is just to disconnect the box from the antenna when you suspect very bad weather.
Hope it helps.
Brian
Dana
Thank you Brian,
Everybody told me the same: the best prevention is to disconect the antenna on the bad weather...
All the best :)
