Changeing longtitude and latitude
Started by davyb, March 02, 2011, 05:13:10 PM
davyb
hi
can anyone tell me how to change the above as my home as imputed wrong location on first instalation .
thanks
andrewarles
Davyb,
On the menu at the top of the page you need to click on "File" and then "Preferences".
You then need to click on the third tab "Home Station Data" and then you enter your Latitude and Longitude.
A mistake that a lot of people make at the beginning is to enter the coordinates in the standard format 43° 30' 0'' which is incorrect and will give an error.  The coordinates must be in decimals ex: 43.5
The easiest way to find your coordinates is on Google earth.  If you have a Smartphone you can also use Google earth that will give the correct format by going to "Options", then "Positions".
Andrew
16 NM SSW of LFMV (Avignon)
27 NM NW of LFML (Marseille)
Arles, France.
Hi Davyb, also if you're in UK and west of Greenwich you must insert a "-" in front of the degrees figure to indicate west, or you'll be in France, Belgium or somewhere equally exotic!
