Speaking of photo's...
Started by prbflight, March 13, 2011, 09:12:54 PM
prbflight
Hi Everyone
Is there a way to update photo's when contacts are made off-line.  I recently had my RadarBox in a different city and recieved about 40 new contacts.  Unfortunately I was not on-line so photo's did not populate.  Now that I'm home I would like to add the photo's to MyLog.  I do not want to add manually as that does not update the aircraft database.  Can this be done?  Thanks.
Paul@cyyb
When on-line, go into Mylog on top left under Mylog is Tools, click on Tools and you will see Populate, press Populate a few times and that should bring on your missing photos if there are any of the particular aircraft.
To update the database you could also download the database update.
Hopefully that will do the trick for you.
prbflight
Thanks for the help Alan but for some reason this does not work for me.  Any other suggestions?
Paul@cyyb
