No military aircraft in MyFlights.
Started by ToxtethOGrady, July 07, 2011, 06:57:01 PM
ToxtethOGrady
That is the weird thing. I can tell if it is a hit off of the network because it will give it's postion in the notification box plus I usually check it by searching the network list. When I check it, it is in the network list. However when a local alert comes thru it does not show up in the MyFlights list or the log. In my alerts section for Mode-S I have ADF* and AE* set up because these are what most U.S. military aircraft use for their address. It always worked before so that is what is strange. Every once in a while one shows up but most don't. All other alerts for civilian aircraft work just fine. When the alerts come thru I am often sitting right at the computer so I can see it as it happens. I also unchecked the Network tab just as an experiment but the problem still occured.  Thanks to chewycanes for the replies.
If this has started to happen recently, backup your data folder and pictures and reinstall. Something may have got corrupted.
ToxtethOGrady
Just upgraded to RadarBox 3D. Still having the same problem with alerts for military aircraft in MyFlights. Had one flight come thru all the rest didn't. Intrestingly, when I do a search filter with a Mode-S address for example, it comes up blank. However when I put the mouse over where a picture should be it will list a copyright name. If I go to Airliners.net manually and search the registartion number and get photos for that aircraft, I can find the copyright holder who took the picture. On the filter search page it's as if the picture is there but you just can't see it or click it.
