Aircraft photos
Started by hugh, February 29, 2012, 07:12:09 PM
hugh
I have added some of my photos to the photo file i can see the photo file in the folder but when i go in the picture section of my log i can not see the photo.
Hi Hugh
Are the aircraft whose photos you've added actually in your log? I think the MyLog Photos tab will only show photos of logged aircraft. That's why there's the button to Explore the Photo Folder if you want to see ALL your photos.
hugh
Thanks for reply when i open My log all photos i see all the photos that are in my photo folder except the one i have put in.
Hugh
Have you named your photos in the same manner as the Airnav ones.
hugh
Yes they are named the same the only differance is the the file size is a little bigger
Hugh
Are they the standard size as per Airnav?
Netcop
Are they in jpeg format?
Greetings from Russia, Moscow
20.54 nm NWN of UUDD
Amp: Wimo AS-1090
RadarBox24 station: Netcop
hugh
Thanks for all the replys will have a go again and see what happens.
Hugh
