left hand side screen not there
Started by crocman, March 12, 2012, 06:45:04 PM
crocman
when i turn my laptop on and my air nav,
my left hand side of my screen is not there with all the aircraft info,
there is just one big map and aircraft,
i have clicked on a aircraft but it does not bring anything up,
if i uninstall air nav from my computer and re install it then everything is there,
what is wrong,
regards iron
Hi Iron
Assuming the menus are showing, go to the Tools menu, choose Interface and click Show/Hide.
If the menus are not showing, you are in full screen view, press ESC to return to the normal view.
Hope that helps.
crocman
thank you so much for your reply,
it worked fine,
thank you very much for your help,
regards iron
