unreal altitude
Started by lebelgepatte, May 01, 2012, 11:55:06 AM
lebelgepatte
hi,
i have some problems with some aircraft showing on -5940ft
all aircraft who is flying @ EBFN or landed is still at -5940ft
i don't know how to change this.
can someone help me plz
go to SmartView
under select airports type in EBFN
tick/set Auto Set QNH
This should reduce the altitude problem.
It's on the tab line - above the Filter line: MyFlights, Network, Smartview, Alerts
surferman
Good morning,
i'm french, sorry for my english, i have don't understand very well what happened to our friend
Quote from: lebelgepatte on May 01, 2012, 11:55:06 AM
hi,
=> The planes that fly to destination EBFN, when they reach the altitude of 5940 ft and continue their descent to EBFN, arnb v3.13 continues to indicate an altitude of 5940 ft? is it exact or I misunderstood
thank you because i use also arnb v3.13
Cordially
lebelgepatte
thx i found the problem.
@ surferman: le problem etais que les avions qui attérisait sur ebfn etais sur une altitude de (-5490ft) a la place de (0ft)
le QNH etais mauvais.
FACTflights
This is interesting.
Someone please translate English.
John
ZS1AGH
No HF antennae at the moment.
John,
If you dont set the QNH to your local setting/Auto, aircraft will display the wrong altitude at that airport on screen
FACTflights
John
ZS1AGH
