Started by orkney, April 06, 2012, 10:35:27 AM
Good find Niklas, very nice photograph.  Its a Cessna 208B Grand Caravan
Many thanks
flygfantast
#1486
Morning Alan
Not populating AC6A79 (N9) which seems to be TC-AYB miscoding (according to Airframes).
N9 is reserved to FAA NATL Flight Program Oversight Office, so that and the altitude of 4980 seems that it's a miscode.
TC-AYB is allocated 4B8722.
TC-AYB, Diamond DA-20-C1 Katana, c/n C0150, Ayjet Flight School
Nikas
Cable: Ecoflex-10 (10m+1m)
X
An unknown Brunei very low for two minutes and a US flyover
* 89501B                                                              2012/07/22 00:50:43
* A13AF6                                                              2012/07/22 02:03:30
X
Hi Niklas,
Makes me wonder why a Turkish DV20 would be over Sweden and also note that Airframes states that A660 EC-FQN has also been noted using the same hex later than the DV20.  As nothing can be confirmed I will put it in as being used by several different aircraft.  The hex was first noted on the network 27/1/2011.
Hi X
A13AF6 decodes to N179DQ, not assigned by FAA and nothing previous found
89501B is unknown to me
54901 - Jim
From this morning's log ...
A84E6B / N634US / CRUZ / CSAW Sportcruiser / US Sport Aircraft Importing LLC / P1102034
Thanks!
KOSH - Oshkosh, Wisconsin USA
X
Another US unknown at around 8000 for six minutes
* A9CB87                                                              2012/07/22 17:06:33
X
X
A9CB87 decodes to N730EZ, Beech C90GT King Air c/n LJ-1808 which is now A6-***  De-registered in March as exported to UAE
X
Thanks probably a mil aircraft at 8000 constant, we will be on the look out
X
orkney
Hello
Please find the new thread here http://www.airnavsystems.com/forum/index.php?topic=7122 . This thread will be kept for reference however.
Thank you
Andrew
