Home station data
Started by paul walker, February 04, 2013, 09:25:32 AM
paul walker
Have just installed airnav on a new windows 8 system and it starts fine but it asks me to enter my home sataion data. On entering the information and clicking ok nothing happens any help would be good
Reds Paul w
Paul,
Are entering in decimal.  Google earth is very good to ensure you get it correct
paul walker
Auto detect does not want to work so find Manchester in the drop down box and latitude and longitude are auto generated then enter my name city country and email press ok an nothing
I never found that to work Paul, give the method I suggest a try and see what happens.  Google earth takes you right to your location.
paul walker
Entered my latitude and longitude using google maps and all the other info clicked ok and still nothing ??
Pual as you are located west of Greenwich did you enter a - before the long.
I also presume you pressed Apply before OK
paul walker
Thanks for the info got it to start ok but now showing no hardware connected bloody windows 8
I presume you downloaded and installed the 64bit drivers from the support website if you have 64bit Windows 8
http://www.airnavsystems.com/download/ANRB/drivers/ANRB64bitDrivers.zip
2E0FLP
Paul,
Have you had the box working and displaying info on the screen with your new system? If not, your correct location info is not an issue at the moment. Also, just having the 64bit drivers is not enough in itself.
Follow the instructions in this link: http://www.airnavsystems.com/forum/index.php?topic=7420.0
Yesterday I installed Radarbox on a new Windows 8 Laptop, a right frig around but got it working in the end, why AirNav can't put any more info on the website support pages surprises me, instead it is burried in the forum Pages. Have Fun !!
Paul
Sorry I presumed you had already done the stuff above
paul walker
Yes 64bit drivers installed and starts ok but keeps saying hardware not connected and there don't seam to be any drivers installed for the USB port that it's plugged in to
Paul,
You have followed the following Windows 8 advice
.From the Metro Start Screen, open Settings (move your mouse to the bottom-right-corner of the screen and wait for the pop-out bar to appear, then click the Gear icon).
2.Click 'Change PC Settings'.
3.Click 'General'.
4.Scroll down, and click 'Restart now' under 'Advanced startup'.
5.Click 'Troubleshoot'.
6.Click 'Advanced Options'
7.Click 'Startup Settings'
8.Click Restart.
9.When Win8 restarts type the number next to "Disable driver signature enforcement"
If still not working are you connected to the computer via a USB hub or direct to the computer.  If via a hub try direct to the computer.  You may also require to have a look at your device manager for the USB ports to see if you require to change something.  If still nothing have a look at your USB cable it may be knackered.
