Problem with the location of my base
Started by RNAGG, February 06, 2013, 03:12:53 AM
RNAGG
I'm having problem with the location of my base when I put the coordinates in my profile.
When I put the latitude and longititude values ​​are exchanged after saving them.
For example, to put my coordinates latitude -23.5089 and longitude -46.5634, see how they look in the file after saving them. My base is right in the middle of the Atlantic Ocean!
Furthermore, the information placed on top are not saved.
Is anyone having this problem?
AirNav 3D Development
Hi RNAGG,
I'm looking into this one right now. I will post here as soon a fix is ready to test. Thanks for catching this.
RNAGG, I fixed this bug so the lat/lng are no longer swapped for station locations. Your station marker should now be showing in the correct location.
QuoteFurthermore, the information placed on top are not saved.
When you mention that "information placed on top" is not saved, what are you referring to?
RNAGG
Now my location is correct!!
"When you mention that "information placed on top" is not saved, what are you referring to?"
It is the information about the user, their location and details about it. Also the address information of facebook and twitter. For some reason this information was not recording.
Now put again and are showing up when I click on my station on the map!
Thanks for the quick reply and solution!
