Incorrect Photo
Started by chrisonmas, March 25, 2013, 02:15:50 PM
chrisonmas
Hi All, sorry if this is the wrong place to post this, but I am still a 'newbe'.
When Oman Air Force C.130H, HEX 70C079, serial 502 is detected, ANRB shows a photo of a MIG on a pole!
Chris
Thanks Chris, photo links have been changed.  Please note that as they links are in your Navdata unless you delete the links, the photo will stay wrong until you install the next Navdata.  If you delete the link then click in the aircraft the next time you pick it up the new photos will download.
If you see anymore please advise on the database update thread,
chrisonmas
Thanks Alan, will do.
Chris
vonsmalhausen
the problem is the serial ; the "Mig on the pole" probably also has 502 as registration, you can download a picture for that Oman AF C130 and name it 502 to replace the Mig, but this is a problem with the military using numbers as reg ; next time it may well be possible you pick up, let's say, a French Mirage, also with 502 as reg : then the Oman C130 pic will show up.
