I am not very happy
Started by gonz33, March 28, 2013, 04:13:30 AM
gonz33
Hi, already installed on the roof of the building where I live the antenna rama  radar 5 dB gain, but I am not very happy since I am comparing when the I had before in the window of my room, the difference is not much, I live in Caracas and I'm convince that Caracas is in a Valley surrounded by mountains and hills, but before when I had the antenna on my window I had a range of 50 miles, and now the more that I see is 70 miles, anyway I'm going to wait a day more to compare again.
#1
Hi Gonz23,
Being in a valley will make some difference to your 360 degree vision but not too much, you should get better distance on either end of the valley but the sides may be a bit limited but not too much.  On the window sill you would only have had around a 180 degree view at best whereas you will be getting 360 degrees now so I  would expect some difference.  Make sure all your connections between the antenna and the receiver are sound also.  Did you use a good cable as if not you will get some loss.
I think you may be getting more distance than you think.  At this time I am watching DTA702 B767 CS-TFM flying over Barbados and TAM8056 which flew over Caracas and is now over 100 miles away from you.  I have never seen aircraft there before and think it may be coming from you.
It will take some time possibly a week or so before you will see a big difference in your polar diagram, give it time.
