My New DPD PRODUCTIONS 9 dBi Antenna.
Started by gonz33, May 25, 2013, 07:18:05 PM
gonz33
Hi all, just finished installing my new DPD PRODUCTIONS 9 dBi antenna, but I've noticed that I get more aircraft but with fewer messages per second and the other is that sometimes has some delay in exit on the screen, the only thing I need to do is change the connector on the cable coming from the antenna that is connected to the radar box for type N connectors because I have it currently with BNC connector, will be is what gives me some problem? Thank you
Gonz,
Regarding the screen delay may be I am not picking up your meaning, have a play with File/Preferences/RadarBox/Timeout For My Flights settings.  I have mine set to 30 and 60.  Also have a look at your Screen Refresh Rate settings try 1000.
If you mean when you close down Radarbox it is just all the data being saved which takes 5-10 second, possibly more depending on you busy your screen has been while on and on how long it has been since your last close down.
gonz33
#2
Hello Runway 31, what I mean is that when my box radar box  captures an aircraft this appears on the screen as 2 or 3 minutes after displaying the information with the blue icon on the side showing the estatuis of my flight.
