Possible issue with supplied antenna
Started by chrisonmas, January 31, 2014, 06:11:58 AM
chrisonmas
Hi guys
I had a bit of a problem with my supplied antenna that I wanted to pass on, hopefully it will prevent it happening to other users.
When in my laptop bag, I unscrew the antenna from its base. Today, when I took it out of the bag, I found the threaded portion normally sticking out of the base, had been pushed in. It was flush with the top of the base, so no chance to screw on the antenna.
If you normally unscrew the antenna during transit, I suggest finding a nut of the correct thread to screw onto the thread.
Hope of use.
Chris
kev_m333
Hi Chris and all,
                          The very same thing happened to me prompting a replacement from W&S. Great idea using a nut as thread protection when not in use.
                                                        Regards  Kev Miller.
