No alerts on radarbox
Started by acars45, June 02, 2014, 04:38:09 AM
acars45
Is there a problem with the alerts nine since Sunday
Night
Seems OK to me.  I set up registration and flight ID alerts for 2 aircraft and received 4 local and 4 email alerts.
fossie1
I'm not getting squawk alerts on 5.00.071
My position is 16 miles north of EGAA Belfast international Airport (Aldergrove)
#3
Since when and on local flights or network.  Also I presume that you picked up the aircraft concerned and it was squawking the code you were looking for.
I would also suggest you contact support as they are the only ones who can assist if here is a problem.
fossie1
#4
I only noticed it tonight. I can't recall having any squawk alerts on this version. My mode s and reg alerts seems to be working fine. It's on local flights.
Stephen
#5
What squawk had you set.  I presume it was 7700 from the easyJet?
fossie1
I have 7760 and 7700. There was an easyjet with an emergency into EGAA and was squawking 7700 but I got no alert. I tried entering other squawks from aircraft out of my range and when they come into range still no alerts.
Stephen
Will look into it in the morning, thanks for advising.
fossie1
Squawk alerts on myflight are not working.  However as soon as I tick the box to activate them for network flights they come flooding in.  I will advise Airnav, I would imaging a new version will be required to correct this.
