No squawk alert
Started by yang, September 20, 2014, 03:36:56 PM
yang
The squawk alert worked fine before. but after I input the following squawk numbers as below in the squawk field today, I did not receive any squawk alert. does the number of squawk in the squawk field has limitation?
000*
001*
002*
003*
004*
005*
006*
007*
010*
011*
012*
013*
014*
020*
021*
0212
022*
023*
024*
0244
025*
026*
027*
030*
031*
032*
033*
034*
035*
036*
037*
04*
05*
070*
071*
072*
076*
077*
100*
101*
102*
110*
111*
112*
113*
114*
115*
116*
117*
120*
1200
121*
122*
123*
124*
125*
1255
126*
127*
1277
130*
131*
132*
133*
134*
135*
136*
137*
140*
141*
142*
143*
144*
145*
146*
147*
150*
151*
152*
153*
154*
155*
156*
157*
160*
161*
162*
163*
164*
165*
166*
167*
170*
171*
172*
173*
174*
175*
176*
177*
200*
201*
202*
203*
204*
205*
206*
207*
210*
211*
212*
213*
214*
215*
216*
217*
220*
221*
222*
223*
224*
225*
226*
227*
230*
231*
232*
233*
234*
235*
236*
237*
240*
241*
242*
243*
244*
245*
246*
247*
250*
251*
252*
253*
254*
255*
256*
257*
260*
261*
262*
263*
264*
265*
266*
267*
270*
271*
272*
273*
274*
275*
276*
277*
I don't know the answer to your query Yang but alerts for squawks are working OK.  I would suggest that you limit to 10 or so squawks that you know you are likely to receive to try them out and you will know that there must be a limit if your receive alerts.
