BEAM FOR ADS-B
Started by Mike_Tassy, April 19, 2010, 10:58:51 AM
Mike_Tassy
I have designed and built an 8 element beam for ADS-B
Simple to build - no guesswork, no tuning  - designed with MMANA  Antenna file here
http://www.users.on.net/~silver.eagle/8EL_ADS-B.maa
Just right click / save file as
Most of my signals come from the Nth/NTH-E of here.  I have a homebuilt collinear which works fantastic, and this beam increases the plots on the edge of range.  250-300 nm
This might be the answer for some users with difficult locations
Note -  The elements are 2 mm diameter copper wire  THIS IS VERY IMPORTANT
Different size wire will affect performance
Mike
g0seg
Hi Mike, good for you. Why don`t you put the design for the collinear as well? I`ll knock one of these up and let you know how it runs - although at the moment i`m only tracking birds!! Bi now and thanks, Roger
juangelb
Hi Mike_Tassy
Nice beam... but I was unable to get the file 8EL_ADS-B.maa
By the way, could You tell me what extention is maa ?
Thanks in advance. Juan
Mike_Tassy
I fixed the link to  8EL_ADS-B .maa   file above
It is antenna model file for MMANA the antenna modelling program
http://mmhamsoft.amateur-radio.ca/pages/mmana-gal.php
Mike
juangelb
Hi Mike_Tassy
Thaks. Already downloaded the file and MMANA.
Tomorrow I will try to make the antenna.
Best regards.
HermanZA
Mike_Tassy,
Are you still using that original antenna design of yours?  Do you have any more information to share with us, like performance, range, beam width, etc?
