Map
Started by bruce, November 19, 2014, 02:58:31 PM
bruce
Am I the only one having this problem, EKCH is in the middle of the sea and not on land.
Hi Bruce - lucky I spotted your message in this forum - it would have been better in the AirNav RadarBox Discussion forum.
Still - the default RadarBox map is pretty crude, but I have done other outlines, including the Armager Island coast outline - add this to your Outlines folder and restart RadarBox - it should appear on the map.
If you want all the outlines available, click my website link (blue globe) on the left.
bruce
Hi Rod
Thanks for your reply, will post in the right forum in future, am new to radar box, bought one
of the units from moonraker.
I have put your site on my favourites, will keep looking there for updates and many thanks
for the outline today
Bruce
No problem - keep an eye on the Logos, Outlines, and New Silhouettes threads in the discussion forum for further updates.
Hi Rod,
regarding your website: Maybe you should consider to put a new version of silhouettes zip file online.  There have been some additions since December 2013. Or is it planned as a christmas present like the last update?
Thanks!
#5
Bruce,
Have you updated the software to  V5.00.72 and have you used the database update feature to keep you up to date  5.00.72 upgrade here http://www.airnavsystems.com/download/anrb/ANRBUpgradeto50072.exe
and full install here http://www.airnavsystems.com/download/anrb/ANRB50072Setup.exe
If doing the full install I would delete all traces of the previous versionfirst.
#6
Hi Ingo - hee hee - yes, it has been a while, but there are only 43 (EDIT: 42) additions since the last zip - still, I'll do one soon.
Done now, Ingo :-)
No christmas present then. ;-)
Thanks!
bruce
Hi Alan
Sorry havnt replied sooner was away.  I did update to the new version but was getting problems with
it, so went back to 71 again.... maybe I should try the full install instead of the upgrade.. I am going
to have to read the manuals a lot more, would like to try updating routes etc.... found one this
morning TOM49T supposed to be out of EGCC in fact its a flight from EGNT to GCTS
Brucce
Thanks Bruce,
5.00.72 has sorted the problem with other users so would update using the full install.  Suggest you delete you original installation first.
Noted TOM49T out of Newcastle heading into Scotland before it turned back south again and added it in.  Catching up with the TOM winter route changes.
