windows 8.1 drivers
Started by captainscud, November 07, 2014, 01:03:25 PM
JD,
Try installing the drivers again using the same procedure as the last time.
Blueboy
Hi Alan, I've sent in a request to Support, I'll see what they suggest
Thanks for your replies
J.D
If windows is saying the drivers are not available it means they are not installed JD
Judwin45
Hi Alan
All up and running now.
Thanks for your help.
Keith
Keith
5 miles south of EGDY
Blueboy
Hi Alan, just to let you know I'm up and running again - I deleted the drivers and re-installed them as you suggested and also followed Supports 9 point instructions - don't know what of the two was the key but RB going again so I'm happy again.
J.D
As long as you are up again that's the main thing JD
MIKE.UTD
Still having trouble with the drivers.
I have downloaded the new win 8 drivers on to my desktop , they are a 7z zip file.
I then extracted then to C:AIRNAVRADARBOX/DRIVERS.
The folder is in here.
I then did the 1-9 but still nothing.
Should I have unzipped them somewhere else ?
Thanks for any help.
Mike.
As advised by Burnley, the drivers are not mentioned on the sticky.  After 9 when the computer restarts, go to Device Manager and right click on AirNav RadarBox.  Update driver and point it to the unzipped 8.1 driver folder.  Accept any warning messages and it will install and work.
MIKE.UTD
Done again and all working, just for anyone else struggling I did the following.
1)Downloaded latest ANRB software.(ANRB not plugged in).
2)In drivers folder deleted all old drivers.(ANRB plugged in now).
3)Downloaded new win 8 drivers zip to desktop, downloaded zip folder in to C:Airnav/Drivers folder.
4)Did 1-9 as per memo.
5)PC then reboots then go to settings/devices, go to Airnav, right click to update drivers and point it to above driver folder.
6)It searched added the new drivers and all is now working.
A big thanks to Alan and everyones help, now up and running.
Mike.
Glad to hear it Mike.  I have advised support and asked them to change the stick instructions
