E-MAILS
Started by capetown, July 16, 2015, 01:06:33 PM
capetown
HI AM UNABLE TO RECEIVE E-MAILS FROM REPORTER AND ALSO FROM SEND NOW ANY ADVICE
I just tried it and its working ok here.  Check what you have as recipient.  Also it is bad etiquette to send in capitals
capetown
recipient is my e-mail address and still not working sorry for capitals its easier with my eyes
#3
No worries then about the capitals given that.
All the expected emails arrived to me from the Airnav logs to mode-s overnight. The systems would then appear to be working OK so no idea on your issue.
Have you looked in your spam folder in case they went in there.
Geot
My Log report did not transmit this evening. An info email from MailEnable says it is waiting at airnavsystems.com for delivery. MailEnable will keep trying to deliver the message for the next 29 hours. So it appears Server is still unstable
Geot.
#5
 I received the usual ones on mode-s the morning from the Airnav server.
However I also received a similar message this morning.  The message I am getting is stating that it cannot contact the mail server at yahoogroup.com.  Looking at the recipient details it is evident this is because I have forgotten the s and the end of yahoogroups.
I corrected my error and resent the log and it arrived within seconds. Therefore I would suggest that you have misspelled the recipients details like I did so maybe you could check.
Geot
I finally received the Log about eight hours after it should have been auto generated. The Address was fine, it is permanently stored in the recipient line. Earlier this month the Log was not auto-generated for about 7 to 10 days, then restarted without any intervention from me.
Geot
That's correct, the emails were down for that time until I advised them
#8
If you can PM or email me with the full text of the mail I will forward to Airnav and advise.  Either that or you can contact support@airnavsystens direct.  Also don't leave for 7-10 days, if advised I can forward to Airnav and usually have whatever the problem is corrected.  If they don't know about it they cant do anything about it.
