Radarbox alerts down ?
Started by acars45, March 02, 2016, 12:22:59 PM
acars45
Already done think you alan tried on my own server still did not work.
Alan can I ask you about micro radarbox what's your view on this ?
No idea, don't have one Paul.  It does the same as your box with the V6 software so should be OK for use when mobile.  You may also want to consider a cheaper option as you can get a DVT stick a lot cheaper and use the same V6 software.
GreekSpy2001
#18
Paul
Have been trying the micro usb with the V6 beta.  I seem to be recieving approx 20% flights each day.  with the original box was getting approx 3500 flights a day now it seems to be around 4200.  Obviously the downside is that the V6 software is a beta code so there are a few bugs with it.
I bought this of Amazon UK
NooElec NESDR Mini 2 USB RTL-SDR & ADS-B Receiver Set, RTL2832U & R820T2  alonf with a BNC to MCX drop cable.
see more info on this thread
http://www.airnavsystems.com/forum/index.php?topic=8474.0
HTH
Graham
GreekSpy2001
" To make matters worse the custom server is option is not working for me either with v6 software.  Not a problem with my mail system as my JSTARS alert app is able to send thru my smtp service ok.  "
Further to this have realised that JSTARS was sending without SSL.  Therefore reconfigured the custom version to send without SSL and alert email coming thru.  Seems like a problem with the SSL setup/handshake
Graham
acars45
Any update on alerts tried in server still not working
If there was an update it would have been advised here
acars45
Alerts working a big thank you Paul
