Autostart ANRB.EXE
Started by A380, March 02, 2010, 06:40:10 AM
A380
Hello,
is there a commandline option in ANRB.exe to automatic press the "Start" Button?
Fred
abrad41
A380
Hi go to the icon on your desktop, right click - then properties. In the Target field enter " /connect" at the end of the entry. Mine shows like this -
"C:\AirNav RadarBox\ANRB.exe" /connect  Make sure there is a space between the " and /
Andy
A380
Works fine, thanks a lot.
Fred
Rural Outpost
Abrad41,
Top tip thank you. I have been trying to do this for months and thought it must be my pants PC stopping me doing it. I wasn't putting the space in.
Ta
Shawn
Chris11
How do you do this in Windows 10
The /connect enables a direct startup without sign-in/login prompt. The software has still to be launched manually.
The how to for enableling the /connect option is still the same in Win10:
- right mouse click on short-cut icon or on the .exe icon.
- goto bottom of the list: properties and left mouse click
- goto sub menu shortcut
- and append /connect after the existing line e.G.: "C:\Eigene Programme\AirNav Systems\AirNav RadarBox\ANRB.exe" /connect <- There must be a space between " and /connect!
- then left click on Ok
- Done
Or do you wish to start the Software with the System Boot? There are several options to get this working. Of course from quite easy to complicated...
HTH Regards Ingo
Chris11
