Data Feeding
Started by NigelR, April 10, 2016, 11:30:41 AM
NigelR
Does anyone know if it is possible to feed data to RB24 direct from a Kinetics Puck? i can't see it as an option under 'Increase Coverage'
I don't see a problem with that Nigel but support@airnavsystems will be able to provide the definitive answer and direct you to the sharing software.
NigelR
Thanks Alan, I'll email them
Nigel
waituke
Whats happened to New Zealand ATC stations not listed anymore
ciao
Kevin  371
#4
Hello Kevin,
with regards to the Australian & New Zealand Data Feeders thread there was and maybe still is a problem with the Comstation to ANRB Server connection. It is possible, that this has (hopefully temporaryly) removed the ATC stations too.
There will never be ATC available in germany as it is by jail forbidden to listen or redistribute ATC conversation. I don't know if there is a similar law in NZ too. If yes it's highly possible that AirNav will deactivate all ATC stations in NZ to protect the persons who are running the comstations at their homes.
#5
Dennis,
VHF is only available and shown on the grid if the feeder is online
