usb port connection
Started by sergiomaria, February 18, 2017, 09:59:19 PM
sergiomaria
Good evening Group.
Lately my radar box seems not work properly,have to check antenna and today for 2 times i got message: usb port not recognized.If i change port where to connect radarbox,have i to reinstall radarbox software?
Thank in advance for suggestions,have a good night.
You don't have to re-install the software, changing USB ports does not cause any issues.  Also problem with the USB cable can cause the same issue.  The issue is not really a big problems as it happens at times and as long as it goes on working there is no problem.
