Author Topic: How to feed RadarBox MLAT to VRS  (Read 21986 times)
volosguard
Re: How to feed RadarBox MLAT to VRS
« Reply #15 on: May 29, 2020, 06:43:39 AM »
Hello. After running sudo nano /etc/rbfeeder.ini
[client]
network_mode=true
key=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
sn=xxxxxxxxxx
lat=xxxxxxxxxx
lon=xxxxxxxxxx
alt=107
sat_used=0
sat_visible=0
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
[dump978]
#dump978_enabled=true
I have Buster installed but you said python 3.7 should be used. How can I fix this please?
  • CYYZ - Toronto
« Reply #16 on: May 29, 2020, 03:17:23 PM »
@volosguard:
(1) Open file rbfeeder.ini to edit
Code: [Select]
(2) In above file, scroll down to this line:
(3) Immediately below above line, copy-paste this line:
mlat_cmd=/usr/bin/python3.7 /usr/bin/mlat-client --results beast,listen,30007
(4) Save file (Ctrl+O) and Close (Ctrl+x)
(5) Restart rbfeeder
Code: [Select]
