Updated Pi, RBFeeder segfaults
Started by thecivvie, July 26, 2020, 10:10:45 PM
Topozero
Thank you very much for the fix. I'm feeding again!
Start-Date: 2020-07-28  12:13:14
Commandline: apt full-upgrade
Requested-By: kemme (1001)
Upgrade: rbfeeder:armhf (0.3.5-20200722181401, 0.3.5-20200727132301)
End-Date: 2020-07-28  12:13:16
But another phenomena occured. After approx. 10 hours the feeds didn't contain any data. The feeding chronology in the web interfaces changed its color to yellow.
The rbfeeder.log tells always the same.
[2020-07-29 08:03:15]  ******** Statistics updated every 30 seconds ********
[2020-07-29 08:03:15]  Packets sent in the last 30 seconds: 570, Total packets sent since startup: 937595
[2020-07-29 08:03:15]  Data sent: 24.9 MB
[2020-07-29 08:03:15]  Data received: 37.8 KB
After restarting the daemon/service I could see om the web interface that the feeds again contained data.
[2020-07-29 09:51:19]  Caught SIGTERM, shutting down..
[2020-07-29 09:51:19]  Starting RBFeeder Version 0.3.5 (build 20200727132301)
[2020-07-29 09:51:19]  Using configuration file: /etc/rbfeeder.ini
[2020-07-29 09:51:19]  Network-mode disabled. Using local dongle.
[2020-07-29 09:51:19]  System: raspberry
[2020-07-29 09:51:19]  Start date/time: 2020-07-29 09:51:19
[2020-07-29 09:51:19]  Socket for ANRB created. Waiting for connections on port 32088
[2020-07-29 09:51:21]  Connection established.
[2020-07-29 09:51:21]  Connection with RadarBox24 server OK! Key accepted by server.
[2020-07-29 09:51:49]  ******** Statistics updated every 30 seconds ********
[2020-07-29 09:51:49]  Packets sent in the last 30 seconds: 255, Total packets sent since startup: 255
[2020-07-29 09:51:49]  Data sent: 11.7 KB
[2020-07-29 09:51:49]  Data received: 1.0 KB
So, my questing is going to those who already have upgraded to version 0.3.5-20200727132301 (@thecivvie). Can you confirm No Data after 10 hours?
#16
Was there traffic in your are at the time it was yellow and were they showing on the map
Topozero
Yes there was/is traffic in this area. And No Data occoured again an hour ago. Well, I checked other stations around here in Germany and I see other stations having a No Data problem recently and right now, i.e:
EXTRPI001117
EXTRPI007581
EXTRPI542729
EXTRPI001556
The outages are more than I have observed in the past. I guess its not due to the recent update. Probably this is another, independent problem.
Perhaps we only have to be patient for another day to see whether the No Data problem will increase or decrease.
#18
Unfortunately I know nothing about Pi's but I wonder if it is OS specific however we shall need to wait and see what Jonis suggests.  Others may be in need of the new feeder software you used.  What is your feeder number, makes it easier to look at the station if you know which one it is being looked at
While you mention Germany others are having no problem, the first 2 below are also in Germany and others don't seem to be having a problems or issues
See these ones taken at random from https://www.radarbox.com/stations/raspberry-pi
https://www.radarbox.com/stations/EXTRPI010357
https://www.radarbox.com/stations/EXTRPI010353
https://www.radarbox.com/stations/EXTRPI010356
https://www.radarbox.com/stations/EXTRPI010394
https://www.radarbox.com/stations/EXTRPI010397
https://www.radarbox.com/stations/EXTRPI010375
I have advised Airnav there may be an issue here so hopefully someone will investigate
Jonis Maurin Ceara
Hi.
We had some issues that cause this problem, but should be fixed now for all clients.
Topozero
Thank you very much. I wasn't patient enough ;-)
