Author Topic: How to install RBFeeder with Raspbian Bullseye?  (Read 27837 times)
teesvalley spotter
Re: How to install RBFeeder with Raspbian Bullseye?
« Reply #15 on: January 28, 2022, 12:22:15 PM »
Now follow NOTE (2) of my "How-to" post, (i.e. edit file /etc/rbfeeder.ini and add your latitude, longitude and altitude, then save file, then restart rbfeeder (or reboor Pi).
I have edited the relevant sections in sudo nano /etc/rbfeeder.ini but it just says MLAT active (No stations synced) I have rebooted the pi
  • CYYZ - Toronto
« Reply #16 on: January 29, 2022, 09:29:04 AM »
Please post output of following command:
Code: [Select]
teesvalley spotter
« Reply #17 on: January 29, 2022, 10:07:18 AM »
Quote from: abcd567 link=topic=105631.msg513631#msg513631
[code
[/code]
Hi. That returns this
rbfeeder.service - RBFeeder Service
     Active: active (running) since Thu 2022-01-27 19:28:42 UTC; 1 day 14h ago
   Main PID: 12619 (rbfeeder)
      Tasks: 10 (limit: 2059)
        CPU: 16min 17.857s
             ├─12619 /usr/bin/rbfeeder
             └─12629 /usr/bin/python3.9 /usr/bin/mlat-client --input-type dump1090 --input-connect 127.0.0.1:32457 --server mlat1.rb24.com:40900 --lat 54.[REMOVED] --lon -1.[REMOVED] --alt 61 --user EXTRPI[REMOVED] --results beast,connect,127.0.>
Jan 29 10:03:53 piaware rbfeeder[12619]: [2022-01-29 10:03:53]  ******** Statistics updated every 60 seconds ********
Jan 29 10:03:53 piaware rbfeeder[12619]: [2022-01-29 10:03:53]  Packets sent in the last 60 seconds: 1, Total packets sent since startup: 86826
Jan 29 10:03:53 piaware rbfeeder[12619]: [2022-01-29 10:03:53]  Data sent: 2.5 MB
Jan 29 10:03:53 piaware rbfeeder[12619]: [2022-01-29 10:03:53]  Data received: 93 B
Jan 29 10:04:26 piaware rbfeeder[12619]: failed to rename /dev/shm//rbfeeder_history_66.json.HQcP6o to /dev/shm//rbfeeder_history_66.json: Operation not permitted (122 more error messages suppressed)
Jan 29 10:04:54 piaware rbfeeder[12619]: [2022-01-29 10:04:54]  ******** Statistics updated every 60 seconds ********
Jan 29 10:04:54 piaware rbfeeder[12619]: [2022-01-29 10:04:54]  Packets sent in the last 60 seconds: 2, Total packets sent since startup: 86828
Jan 29 10:04:54 piaware rbfeeder[12619]: [2022-01-29 10:04:54]  Data sent: 2.5 MB
Jan 29 10:04:54 piaware rbfeeder[12619]: [2022-01-29 10:04:54]  Data received: 93 B
Jan 29 10:05:26 piaware rbfeeder[12619]: failed to rename /dev/shm//rbfeeder_history_68.json.Odwozq to /dev/shm//rbfeeder_history_68.json: Operation not permitted (122 more error messages suppressed)
  • CYYZ - Toronto
« Reply #18 on: January 29, 2022, 01:03:26 PM »
@teesvalley spotter
You have two wrong entries in your file rbfeeder.ini
Please see green arrows in screenshot of my file rbfeeder.ini attached below.
To correct these errors, plase do this:
(1) Open file rbfeeder.ini for editing
Code: [Select]
(2) In file opened, under [client]
change
network_mode=false
to
network_mode=true
(3) In file opened, under [network]
change
external_host=192.168.xx.xx
to
external_host=127.0.0.1
(4) Save file (Ctrl+O) and Close (Ctrl+x)
(5) Restart rbfeeder
Code: [Select]
(6) Check status
Code: [Select]
teesvalley spotter
« Reply #19 on: January 29, 2022, 06:24:57 PM »
Thanks for your help, the MLAT client is now working and syncing
Av8tor_from_Argentina
« Reply #20 on: February 09, 2022, 05:50:00 PM »
Amazing job gentleman.. Same problem that guys from above, Support from Radarbox24 useless... You guys here helped a lot... seems like RB script from webpage is for buster, not Bullseye.
Now  I´m online again (WORKED ONLY FOPR 5 MINUTES)
After 5 minutes, stopped working... Any clue about this ? I have working FR24, Planefinder, Flightaware perfectly.
@raspberrypi:~ $ sudo rbfeeder --status
[2022-02-09 15:10:39]  Starting RBFeeder Version 0.4.3 (build 20210909231001)
[2022-02-09 15:10:39]  Using configuration file: /etc/rbfeeder.ini
[2022-02-09 15:10:39]  Network-mode enabled.
[2022-02-09 15:10:39]           Remote host to fetch data: 127.0.0.1
[2022-02-09 15:10:39]           Remote port: 30005
[2022-02-09 15:10:39]           Remote protocol: RAW
Error opening the listening port 32458 (Raw TCP output): bind: Address already in use
 less /etc/rbfeeder.ini
disable_log=0
key=xxxxxxxxxxxxxx
sn=EXTRPI0xxxxx
lat=xxxx
lon=xxxx
alt=28
[network]
mode=raw
external_port=30005
[mlat]
autostart_mlat=true
[dump978]
#dump978_enabled=false
less /var/log/rbfeeder.log
[2022-02-09 15:08:22]  Using configuration file: /etc/rbfeeder.ini
[2022-02-09 15:08:22]  Network-mode enabled.
[2022-02-09 15:08:22]           Remote host to fetch data: 127.0.0.1
[2022-02-09 15:08:22]           Remote port: 30005
[2022-02-09 15:08:22]           Remote protocol: RAW
[2022-02-09 15:08:22]  Starting RBFeeder Version 0.4.3 (build 20210909231001)
[2022-02-09 15:09:19]  Starting RBFeeder Version 0.4.3 (build 20210909231001)
[2022-02-09 15:09:19]  Using configuration file: /etc/rbfeeder.ini
[2022-02-09 15:09:19]  Network-mode enabled.
[2022-02-09 15:09:19]           Remote host to fetch data: 127.0.0.1
[2022-02-09 15:09:19]           Remote port: 30005
[2022-02-09 15:09:19]           Remote protocol: RAW
Above, you have logs and ini to see my config. How to know if MLAT client is working for RB24? Is working fine with FR24 and Flightaware...
Help Help.--.
« Last Edit: February 09, 2022, 06:20:55 PM by Av8tor_from_Argentina »
« Reply #21 on: February 09, 2022, 06:37:52 PM »
I know next to nothing regarding Linux but while waiting on abc123 I did note the following error
[network]
mode=raw
external_port=30005
Should be mode=beast
« Reply #22 on: February 10, 2022, 12:17:04 AM »
[network]
mode=raw
external_port=30005
Alan, thank you for the observation, but that was suggested by Support from RB24. Annoying...
Lets wait for the Wizard of ADS-B
  • CYYZ - Toronto
« Reply #23 on: February 10, 2022, 02:12:09 AM »
You are using wrong command (sudo rbfeeder --status) to check status. This started 2nd copy of rbfeeder, while 1st copy started by system was already running and using the ports. This resulted in Error message and failure.
Use following command to check status
NOTE:
(1) First in file /etc/rbfeeder.ini, change the error mode=raw to mode=beast
(2) Next save file
(3) Next Reboot RPi
(4) Now issue following command:
Code: [Select]
[network]
mode=raw
external_port=30005
As already pointed out by Alan, mode=raw is wrong. It should be mode=beast.
« Last Edit: February 10, 2022, 03:24:41 AM by abcd567 »
anorak
« Reply #24 on: February 16, 2022, 04:13:11 PM »
Hi abcd567, is your Bake a Pi thread the best way to load a Pi, or with the updates is there a better script please?
Thanks, Dave.
Dave. Exmoor, North Devon.
  • CYYZ - Toronto
« Reply #25 on: February 17, 2022, 12:05:08 AM »
Thanks, Dave.
Hi Dave
I have not looked at my "Bake A Pi" howto for a long time. It is 2017 howto, and many changes have taken place during these 5 years. Obviously many procedures given in it most likely have become outdated.
Ok, this weekend (or may be next weekend) I will review it and update it. It may take more than one weekend.
abcd
anorak
« Reply #26 on: February 17, 2022, 10:43:43 AM »
Don`t worry how long it takes, if any one can, you can.
Your efforts are always appreciated, Dave.
