Author Topic: sudo: rbfeeder: command not found  (Read 16759 times)
  • CYYZ - Toronto
Re: sudo: rbfeeder: command not found
« Reply #15 on: January 23, 2022, 11:55:44 PM »
Hi. Thanks for the reply above. I have piaware SD card latest version installed I haven't got access to my pi at the moment. I can get the picture tomorrow.
No need to post screenshot. You have Piaware SD card which has dump1090-fa pre-installed.
Open file rbfeeder.ini for editing
Code: [Select]
sudo nano /etc/rbfeeder.ini
In file opened, do following
(1) under [client] change from "network_mode=false" to "network_mode=true"
and
(2) under [network] make it like below:
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
(3) Save file (press Ctrl and O keys together), then close file (press Ctrl andX keys together)
(4) Restart rbfeeder
Code: [Select]
(5) Check status of rbfeeder
Code: [Select]
Please dont forget to feed-back if you succeeded or not.
cloud9surfer
« Reply #16 on: January 24, 2022, 12:50:37 AM »
Looks to be running as it should now.
[client]
network_mode=true
disable_log=0
key=#######
sn=EXTRPI015836
lat=51.#####
lon=-114.#####
alt=1122
sat_used=0
sat_visible=0
[network]
mode=beast
external_port=30005
[mlat]
autostart_mlat=true
[dump978]
#dump978_enabled=true
rbfeeder.ini.   with key and lat/long ##hidden
« Last Edit: January 24, 2022, 01:04:42 AM by cloud9surfer »
teesvalley spotter
« Reply #17 on: January 24, 2022, 11:24:34 AM »
Hi. I have followed the above and get the following back
Aerotower
« Reply #18 on: February 17, 2022, 08:31:58 PM »
You are online, so no problem!
« Last Edit: February 17, 2022, 08:33:34 PM by Aerotower »
