Help
Started by Paulc, June 28, 2008, 07:18:35 PM
dudbaker
Hello
I have tried  1.  not sharing  2. not getting flights from network  3. not down loading photos 4.  deleting my flights but CPU still peaks at 75%.  The only way to drop it is to disconnect the antenna.  Even using the supplied antenna has 75%.
Deleting my flights did stop the hanging and allowed me to open files tab.  Deleting dropped the memory usage down to 90600 which I belive was 156000.  What i could do with is a way of deleting civil flights.
Dudley Baker
Stansted
G8THH
What is your pc specs dubaker?
As ifs its reaching 20% even with closed you either have a slow pc or there are quite few other things running in the background.
steveb25
Hi all
Tarbat mentioned recently that you can run RB2008 without 'running as administrator' when i try this my hardware does not connect. (The liitle box stays red) anybody else had this problem?
dudbaker
Airnav support
I have a Dell Dimension 5150 if that helps.  I deleted all the aircraft in Mylog this morning and it is working fine.  When it gets to 6000 aircraft it will become difficult to use and hang.
I can live with this but I would like not to have to delete aircrft if possible especially if others do not have to.
Dudley Baker
Stansted
G8THH
