Author Topic: UAT978 connected no data transmitted  (Read 19531 times)
  • CYYZ - Toronto
Re: UAT978 connected no data transmitted
« Reply #15 on: March 15, 2022, 03:36:46 PM »
abcd
 reviewing your last:
The dump978-rb matches mine
The edit command for "/usr/share/dump978-rb/start-dump978-rb" returns directory does not exist.
So question should I creat a folder and file to match your post of the start-dump978-rb file?
You can create the missing file & folder manually. However there may be other files / folder also missing / corrupted. A better way is to reinstall dump978-rb as follows:
Run following commands, and it will reinstall dump978-rb with all missing components and overwrite any corrupted/broken files as well:
Code: [Select]
sudo apt update
sudo apt install --reinstall dump978-rb
sudo systemctl restart dump978-rb
After above commands are completed, check if file "/usr/share/dump978-rb/start-dump978-rb" exists. Also run following command to see status of dump978-rb:
Code: [Select]
sudo systemctl status dump978-rb
« Last Edit: March 15, 2022, 03:44:45 PM by abcd567 »
Rotex43
« Reply #16 on: March 15, 2022, 04:37:25 PM »
abcd
Appears to work after swapping out sd cards and going back to a previous install, editing some settings.
 The install on the one card was missing or had corrupted critical files.
Thanks for the assistance. Wrapping my old brain around an unfamiliar operating system is rather taxing.
djdegroate
  • EXTRPI636062
    • Gramworthy's
« Reply #17 on: January 16, 2025, 03:01:57 AM »
This is the closest I have come to understanding why my 978 isn't feeding.  When I attempt to "reinstall" dump978-rb it tells me "unable to locate package dump978-rb"
Not sure where to go from here.  I had this all working on my old Pi, but since attempting to get it working on my New Pi5, I've changed the serial number on the 978 dongle, and now it wont work on the old one either.
« Reply #18 on: January 16, 2025, 01:27:06 PM »
Please post your ini file with your log in details redacted
djdegroate
  • EXTRPI636062
    • Gramworthy's
« Reply #19 on: January 18, 2025, 01:10:41 AM »
[client]
network_mode=false
dump_device=1
key=***
sn=***
lat=41.452246000000002
lon=-74.410655000000006
alt=186
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
[dump978]
dump978_enabled=true
  • CYYZ - Toronto
« Reply #20 on: January 23, 2025, 01:26:54 AM »
Please see attached screenshot. I tried, and got same responce.
The problem is with RB24 repository.
Please send an email to support
djdegroate
  • EXTRPI636062
    • Gramworthy's
« Reply #21 on: January 23, 2025, 01:31:26 AM »
Will do, thank you for verifying I wasn't crazy lol
