Author Topic: mlat error  (Read 24357 times)
  • CYYZ - Toronto
Re: mlat error
« Reply #30 on: July 18, 2022, 08:54:34 PM »
This is the correct format /etc/network/interfaces for wifi
Code: [Select]
source /etc/network/interfaces.d/*
# Network is managed by Network manager
auto lo
iface lo inet loopback
iface wlan0
  hwaddress ether xx:xx:xx:FC:76:3F
Are you using Wired connection Ethernet (eth0) or WiFi (wlan0)?
Try this:
Code: [Select]
sudo nmtui
Go to "Edit a connection"
Choose "Ethernet" OR "Wi-Fi", whichever you are using, then highlight "Edit" and press Enter Key.
You will see MAC address under "Device"
Taxom
Re: mlat error
« Reply #31 on: July 19, 2022, 09:21:25 PM »
Yes I'm using wifi connect to my pi.
At some point MAC started to change after every reboot. I would like MAC to stay default.
I found solution to delete NetworkManager but I'm not sure if it works and  doesn't break system.
My "device" field is empty.
Thanks in advance.
  • CYYZ - Toronto
Re: mlat error
« Reply #32 on: July 19, 2022, 09:50:08 PM »
Thanks in advance.
Does your OrangePi has an integral WiFi or you have plugged-in a USB WiFi dongle?
https://forum.armbian.com/topic/4876-orange-pi-zero-random-mac-address-split-from-bpi-r1/
https://blogs.gnome.org/thaller/2016/08/26/mac-address-spoofing-in-networkmanager-1-4-0/
« Last Edit: July 19, 2022, 10:05:10 PM by abcd567 »
Taxom
Re: mlat error
« Reply #33 on: July 20, 2022, 02:44:44 AM »
I have a problem again. ((
Now the mlat is working fine, but rbfeeder cannot connect to the server. Feeders for other services work fine.
I did not touch anything in the settings.
Yes my Pi has an integral WiFi.
  • CYYZ - Toronto
Re: mlat error
« Reply #34 on: July 20, 2022, 02:55:35 AM »
(1) Reboot Pi, then after 10 minutes check if your station connected:
radarbox24.com/stations/EXTRPI014534
(2) You will have two (2) MAC addresses, one for wired connection (eth0) and other for WiFi (wlan0)
« Last Edit: July 20, 2022, 03:00:48 AM by abcd567 »
