Author Topic: Radarbox switch to Bullseye ok, but issue with VHF stick.  (Read 22424 times)
RZEE
Re: Radarbox switch to Bullseye ok, but issue with VHF stick.
« Reply #15 on: November 05, 2022, 09:41:34 PM »
Almost impossible to post on this forum, please check attachment
« Reply #16 on: November 07, 2022, 11:03:18 AM »
What did support advise when you contacted them?
RZEE
« Reply #17 on: November 07, 2022, 07:00:26 PM »
This is the support reply:
Quote
We don't have a version for that release yet, it is being worked on.
« Reply #18 on: November 07, 2022, 08:03:38 PM »
I was meaning the CleanTalk issue you are having
RZEE
« Reply #19 on: November 12, 2022, 08:04:00 AM »
Quote
Unfortunately, i don't want to spend time on such conversations. It's your problem not mine. Despite the good help from abcd567 Radarbox seems not yet compatible to Bullseye despite its out for more than a year now. Cleantalk is throwing too much barriers, to continue this conversation. Hopefully we will see Bullseye support completed soon, and PI users are able to set it up easy with a good guide so we can skip this very user unfriendly forum software, i'm patiantly will look foreward to this moment. Remember we pay for the hardware.
« Reply #20 on: November 12, 2022, 04:13:31 PM »
Its no problem of mine, I dont have issues with Cleantalk and I am not Airnav and like you I pay for my hardware.  Radarbox is compatible but VHF is not but as abcd advises there is a workaround available at this time thanks to his work.
I would have thought having problems with forum access that the first port of call to fix it would be to advise Airnav to see if they could give you some advice or perhaps find a way of letting you through but hey ho as stated its no problem of mine and I will not try to help in the future
« Last Edit: November 12, 2022, 06:07:49 PM by Runway 31 »
RZEE
« Reply #21 on: May 18, 2023, 04:14:29 PM »
Any update on the Bullseye compatibility for the Airband, it's been a while ?
« Reply #22 on: May 18, 2023, 08:32:36 PM »
You need to  ask Airnav
Aerotower
« Reply #23 on: October 20, 2023, 09:58:13 PM »
Quote
That's why I don't use rtl-airband-rb and use rtl_airband
