Author Topic: Strange Problem with Firefox, no aircraft visible  (Read 16086 times)
Stevo
Re: Strange Problem with Firefox, no aircraft visible
« Reply #15 on: November 24, 2022, 07:56:23 PM »
I registered because i have the same issue.
Running firefox under debian linux bullseye radarbox displays aircraft fine. There where some updates of firefox recently (edit: firefox-esr goes from 91.X to 102.X) and i think this broke something.
Now with firefox 102.5.0esr (64-Bit) is is as the threadopener say - same issue here.
testing on another machine running windows 10 with firefox 107.0 same issue as the threadopener says. same machine with edge there are no problems.
i really would like to have it solved because i like to use it with my daily debian machine...
« Last Edit: November 24, 2022, 08:10:38 PM by Stevo »
« Reply #16 on: November 24, 2022, 08:17:10 PM »
suggest you contact support direct as they dont come on the forum very often  [email protected]
Stevo
« Reply #17 on: November 24, 2022, 09:30:03 PM »
thanks for the advice, i mailed them the issue.
Bernhard
« Reply #18 on: November 25, 2022, 12:18:58 PM »
Something is happening right now, just tried again in Firefox and it started with actually less items than before, like no most viewed bar and no options but after some clicking here and there and a few seconds of patience everything is back to normal! Aircraft are visible and clickable. Nice.
« Last Edit: November 25, 2022, 03:14:51 PM by Runway 31 »
« Reply #19 on: November 25, 2022, 03:16:02 PM »
Computers are wonderful things!!  Possibly the developers had a look and made a few changes for the new Firefox version
eagle11
« Reply #20 on: November 25, 2022, 06:48:39 PM »
I had the same problem since a few days but in Edge and that is now also solved.
Since when the problem started I don't know because I normally use Radarbox software (6.02.003) for logging.
Frans
Stevo
« Reply #21 on: November 25, 2022, 08:11:18 PM »
as suggested and mentioned above, i contacted support.
support emailed me this morning if i can confirm that the issue is solved and i did so. same machines and the problems are gone.
well done support, esp for the linuxers ;-)
stevo
anorak
« Reply #22 on: November 26, 2022, 05:42:56 PM »
Klingon cloaking device turned off?
Just thinking, Dave.
Dave. Exmoor, North Devon.
« Reply #23 on: November 26, 2022, 06:27:27 PM »
Thanks for advising Stevo, once they become aware of the issue it is usually fixed quite quickly
