Radarcape ADS-B Receiver Feeding Radarbox Network
Started by QC91, December 29, 2022, 10:01:19 PM
QC91
I change the external_port=10003  /etc/rbfeeder.ini  but sill not sending I found few errors
#32
Quote from: QC91 on January 04, 2023, 07:34:45 PM
Thanks. Yes tried the same setting on the Radarcape but still not working, there is a problem with my feeding of air squitter it shows my feeder online, but it's not sending any aircraft data. Should I change the   mode=raw External_port=10003
No harm in trying different settings of data type and port. You may finally find the right one by trial & error.
You may try different value of external_host as well.
On Airsquitter Linux air-squitter 5.4.11-1-opz :
(1) Check file /etc/fr24feed.ini to see what data type & port it is using
(2) Issue following commands to find what data type & port Flightaware is using
sudo piaware-config -show receiver-port
sudo piaware-config -show receiver-host
QC91
I tried to look at /etc/fr24feed.ini, but it's blank
sudo piaware-config -show receiver-port  is showing  30005
sudo piaware-config -show receiver-host  showing nothing
QC91
I also wanted to mention that I'm feeding to adsbexchange  using this ADS-B Exchange Setup Scripts https://www.adsbexchange.com/forum/threads/help-with-ads-b-exchange-setup-scripts-on-radarcape.637122/
Here is my output for ADS-B Exchange https://pastebin.com/RS0xZSqu
#35
Quote from: QC91 on January 06, 2023, 01:30:03 AM
May be FR24 is through Docker??
How did you install fr24feed?
Piaware uses Beast format. So at port 3005 Beast format is made available by Airsquitter. Radarbox24 also uses Beast and port 30005
No output means host is not set. In this case it uses default host which is 127.0.0.1
Quote from: QC91 on January 06, 2023, 01:47:03 AM
cat /etc/default/adsbexchange will show settings
Possibly it may be as follows:
INPUT="IP-OF-AIRSQUITTER:10003" (or 127.0.0.1:10003)
and
INPUT_TYPE="radarcape_gps"
QC91
I did not install FR24. It was  integrated with the  Airsquitter
Here is the output for adsbexchange
jetvision@air-squitter:~$ cat /etc/default/adsbexchange
INPUT="127.0.0.1:10003"
REDUCE_INTERVAL="0.5"
# feed name for checking MLAT sync (adsbx.org/sync)
# also displayed on the MLAT map: map.adsbexchange.com/mlat-map
USER=
LATITUDE=
LONGITUDE="
ALTITUDE="44m"
RESULTS="--results beast,connect,localhost:30104"
RESULTS2="--results basestation,listen,31003"
RESULTS3="--results beast,listen,30157"
RESULTS4="--results beast,connect,localhost:30154"
# add --privacy between the quotes below to disable having the feed name shown on the mlat map
# (position is never shown accurately no matter the settings)
PRIVACY=""
MLATSERVER="feed.adsbexchange.com:31090"
TARGET="--net-connector feed.adsbexchange.com,30004,beast_reduce_out,feed.adsbexchange.com,64004"
NET_OPTIONS="--net-heartbeat 60 --net-ro-size 1280 --net-ro-interval 0.2 --net-ro-port 0 --net-sbs-port 0 --net-bi-port 30154 --net-bo-port 0 --net-ri-port 0 --write-json-every 1"
#37
To check if fr24feed is through docker, issue following command
sudo docker container ls -a
Please see attached screenshot:
QC91
I did the sudo docker container ls -a   but I get
sudo: docker: command not found
QC91
Hi, it's now working I changed the port to 10006 and  sudo systemctl restart rbfeeder  and it's now sending but I do see this error Process: 3648 ExecStartPre=/bin/mkdir /var/run/rbfeeder (code=exited, status=1/FAILURE)
Quote from: QC91 on January 07, 2023, 07:36:30 PM
This message at restart is normal. It is caused by fact that the folder "/var/run/rbfeeder" was already created at boot. The attempt to create an existing folder results in error message.
Please see screenshot I have attached. This status was after I restarted rbfeeder.
QC91
I wanted to thank you agin for all the help. It's feeding just trying to get MLAT setup. I have the mlat-client installed will post output but looking at the sudo nano /etc/rbfeeder.ini  I don't see (latitude) (longitude) or antenna height should I add them in the instructions post at https://forum.radarbox24.com/index.php?topic=101771.msg389571#msg389571
jetvision@air-squitter:~$ sudo systemctl status mlat-client
● mlat-client.service - LSB: Multilateration client
   Loaded: loaded (/etc/init.d/mlat-client; generated)
   Active: active (exited) since Sun 2023-01-08 23:59:09 UTC; 6min ago
     Docs: man:systemd-sysv-generator(8)
  Process: 252 ExecStart=/etc/init.d/mlat-client start (code=exited, status=0/SUCCESS)
Jan 08 23:59:09 air-squitter systemd[1]: Starting LSB: Multilateration client...
Jan 08 23:59:09 air-squitter mlat-client[252]: Not starting mlat-client daemon, disabled via /etc/defau
Jan 08 23:59:09 air-squitter systemd[1]: Started LSB: Multilateration client.
lines 1-9/9 (END)...skipping...
Jan 08 23:59:09 air-squitter mlat-client[252]: Not starting mlat-client daemon, disabled via /etc/default/mlat-client ... (warning).
Quote from: QC91 on January 09, 2023, 12:15:37 AM
Yes, you have to add your Lat, Lon, and alt in file /etc/rbfeeder.ini under [client] as I have shown in the post yo have linked.
After adding Lat, Lon, Alt and saving the file, restart rbfeeder by sudo systemctl restart rbfeeder.
After restart, check status by command sudo systemctl status rbfeeder. You should see  3rd line (starting with /usr/bin/python3.9) under CGroup :
             ├─592 /usr/bin/rbfeeder
             └─674 /usr/bin/python3.9 /usr/bin/mlat-client --input-type dump1090 --input-connect 127.0.0.1:32457 --server mlat1.rb24.com:4>
Mlat-client is started and kept running by rbfeeder when you add Lat, Lon, and Alt to file rbfeeder.ini. Since you have not done this, the mlat-claient is starting and then stopping.
QC91
Thank you. I do see it now, and it's showing MLAT active (No stations synced) radarbox.com
GeoAir.pt
Hello all.
Has anyone been successful feeding Radarbox network from a Radarcape receiver?
I tried to follow the steps indicated in this thread but didn't succeed :(
When I run sudo rbfeeder the output is:
Quote[2024-09-26 11:44:40]  Starting RBFeeder Version 1.0.10 (build 20240111143100)
[2024-09-26 11:44:40]  Using configuration file: /etc/rbfeeder.ini
[2024-09-26 11:44:40]  Network-mode enabled.
[2024-09-26 11:44:40]           Remote host to fetch data: 127.0.0.1
[2024-09-26 11:44:40]           Remote port: 30005
[2024-09-26 11:44:40]           Remote protocol: BEAST
[2024-09-26 11:44:40]  Using GNSS (when available)
[2024-09-26 11:44:40]  Start date/time: 2024-09-26 11:44:40
[2024-09-26 11:44:40]  Socket for ANRB created. Waiting for connections on port 32088
Segmentation fault
Thank you for any suggestion.
