Author Topic: Invalid email/password  (Read 23837 times)
gilemery
Re: Invalid email/password
« Reply #30 on: August 10, 2023, 03:28:02 PM »
I cant do that where I am using it right now.
I will try though at home to see what happens on my laptop.  There isnt a way for me to move the workstation close to the window..
« Reply #31 on: August 10, 2023, 07:58:27 PM »
I look forward to hearing how it goes
gilemery
« Reply #32 on: August 11, 2023, 12:58:05 PM »
The airport in town is also a national guard base, and is a landing spot for lots of overseas flights when the return.
Question is-- they do not use ADSB?  Heard a bunch take off a bit ago and saw nothing on the app on my computer.
« Reply #33 on: August 11, 2023, 01:26:55 PM »
What type of aircraft, if fighter types probably mode-s only if anything at all
« Last Edit: August 11, 2023, 01:30:30 PM by Runway 31 »
gilemery
« Reply #34 on: August 11, 2023, 01:31:15 PM »
Anything and everything , is that something the flight stick doesn't pick up?
gilemery
« Reply #35 on: August 11, 2023, 01:32:42 PM »
Oh I see that I need to use the 1090 antenna , will try that today
« Reply #36 on: August 11, 2023, 02:29:44 PM »
Flight stick will only pick up the signal from the aircraft, some military dont give any signal usually fighter types
gilemery
« Reply #37 on: August 12, 2023, 05:20:20 PM »
Outside at my house I can get around 67NM with the green flight stick and the 1090mhz antenna, definitely better ,
Now to spend money to expand range
I am about 50 driving miles north of KBOS, can see some of the approach and departure when they head north.
« Reply #38 on: August 13, 2023, 01:09:18 PM »
The higher you can get the antenna the better, height is king
I use this one https://dpdproductions.com/collections/aviation-base-mobile-antennas/products/ads-b-vertical-outdoor-base-antenna
Its in my attic surrounded by all the clutter my with has in there and am getting 155nm
https://www.radarbox.com/stations/EXTRPI565683
« Last Edit: August 13, 2023, 01:12:41 PM by Runway 31 »
  • CYYZ - Toronto
« Reply #39 on: August 20, 2023, 02:29:55 PM »
I have 2 RPi's as follows:
Pi 1:
With 1090 MHz Flightaware Antenna, mounted indoor in my apartment near a glass Window
https://www.radarbox.com/stations/EXTRPI000035
My max range is 358 NM
Pi 2:
With 1090 MHz DIY V-Stub Antenna mounted indoor in my apartment near a glass Window
https://www.radarbox.com/stations/EXTRPI000036
My max range is 356 NM
« Last Edit: August 20, 2023, 02:31:33 PM by abcd567 »
gilemery
« Reply #40 on: September 14, 2023, 12:08:28 PM »
I purchased that  RB Xboost Antenna and have it sitting in my window on the second floor. I am amazed how far I can reach now, I would not have thought that I would have had reception for as far away as this has given me.
