Author Topic: Micro RadarBox dongle/antenna question  (Read 30268 times)
Tramline
Re: Micro RadarBox dongle/antenna question
« Reply #30 on: November 07, 2023, 08:21:42 PM »
Hi Alan and abcd567
I've plugged in the dongle and clicked on Device and checked the box but the R2838U does not appear in the list, I've got 6 devices listed;
Bulk-in, interface (interface 0)
HP Wide version HD (interface 0)
Bulk-in, Interface (interface 1)
USB Reciever (Interface 1)
Intel(R) Wireless Bluetooth (R)
USB Receiver (interface 1)
No sign of the dongle though, but its plugged in and lit up?
Any thoughts? Sorry, I thought this was going to be simple!  My IT skills are hampered by my dyslexia!
Located 2 miles South of LHR.
« Reply #31 on: November 07, 2023, 08:29:15 PM »
Phil
Tick Options/Ignore hubs or composite parent and hopefully it will appear
Tramline
« Reply #32 on: November 07, 2023, 08:40:44 PM »
Alan,
When I tick options and ignore hubs or composite parent the dongle does not show, just the 6 listed, however, when ignore hubs or composite parents is UNCHECKED I get 9 devices showing one of them being the R2838UHIDIR (Composite Parent) but it shows a different driver so I quickly ignored that - but when checking the ignore hubs composite parent the dongle is not showing!
I’m at a loss… any more thoughts?
Tramline
« Reply #33 on: November 07, 2023, 08:42:09 PM »
I just plugged in the black microstick and that’s working without any issue….
  • CYYZ - Toronto
« Reply #34 on: November 08, 2023, 01:12:55 AM »
Select "R2838UHIDIR (Composite Parent)", do not bother for driver shown, and click "Reinstall Driver".
Tramline
« Reply #35 on: November 08, 2023, 01:27:48 AM »
Hi abcd567,
Just to clarify, should the driver shown in the left hand box be deleted as it’s different from the one shown on the right hand box?
Just checking before I do anything daft…
Paul
  • CYYZ - Toronto
« Reply #36 on: November 08, 2023, 01:55:47 AM »
Do not do anything to the drivers shown even if these are different. Just click the box "Reinstall Drivers".
Tramline
« Reply #37 on: November 08, 2023, 09:06:21 AM »
Hi abcd567,
Thanks for the reply.
I've taken a screenshot of the Zadig driver dashboard.  I had a system warning come up asking if I really wanted to change the system drivers?
For the sake of fear of causing problems or conflicts with my computer and other installations I've taken a screenshot and held back from actioning anything.
The button says replace driver?  Would the driver it replaces solely affect my RB Green Flightstick?  I'm probably being over cautious but I dont have the IT skills as others do to sort out things if they go wrong!
Grateful for any thoughts,
Paul
  • CYYZ - Toronto
« Reply #38 on: November 08, 2023, 10:27:46 AM »
If it was my computer, I will take the risk and go ahead and click the "replace driver" button.
 Since you said you have limited IT skils, I don't want to tell yiu to go ahead and click replace driver button.
Please watch this youtube video. It may help you.
https://youtu.be/LWyswHcE5dU
« Reply #39 on: November 08, 2023, 02:38:29 PM »
Paul
Sorry I had to leave the thread as I had other matters to take care of
Microsoft believes that their drivers are better than anyone elses and you dont need anything else and installing other manufacturers drivers will make it inferior even if the item will not work without them, hence the warning from Windows.  Other USB items on your computer will work normally
It used to be that following a windows update that the stick would not work as the update had replaced the driver and we had to reinstall again but it has not occured for a while but if it does do a reinstall
Tramline
« Reply #40 on: November 08, 2023, 04:57:16 PM »
Thank you again for returning to my somewhat paranoid thread!
So can you confirm I can add that driver listed in the lefthand box for the 2838U (Composite Parent) without issue and then the Greenstick should work without any conflict on my other USB dongles?
My IT skills are very poor and my dyslexia hampers most things - God knows spotting takes it's toll in itself!
Thanks again to you and abcd567
  • CYYZ - Toronto
« Reply #41 on: November 08, 2023, 05:25:55 PM »
Paul & Alen
Have you watched the Youtube Video I have linked in my above post?
Please see carefully at 1:28 minutes and 1:39 minutes what presenter's mouse arrow is clicking. I have taken screenshot of these two instances and attaching these below.
Paul:
Please click YES to following Warning:
"You are about to modify a system driver. Are you sure this is what you want?".
This is what is shown in video and I have attached it's screenshot.
« Last Edit: November 08, 2023, 05:27:29 PM by abcd567 »
« Reply #42 on: November 08, 2023, 05:51:11 PM »
Yes I have seen it thanks,  sorry I though what I had stated earlier was clear, I am happy to advise to replace the driver
« Last Edit: November 08, 2023, 06:40:30 PM by Runway 31 »
Tramline
« Reply #43 on: November 08, 2023, 08:21:32 PM »
Hi Alan and abcd567,
I'm delighted to say my Green Flightstick is up and running following the installation of the driver as you suggested.
I'm chuffed to bits but it wouldn't have happened without your patient support and guidance.
Thank you very much, once again!
Kind regards,
Paul
  • CYYZ - Toronto
« Reply #44 on: November 08, 2023, 11:03:49 PM »
CONGRATULATIONS!!!
Glad to know that your Green Flightstick is up and running!
