Author Topic: Network Down ?  (Read 27345 times)
Re: Network Down ?
« Reply #15 on: July 24, 2007, 04:51:56 PM »
Is the network down?
Tue 24 Jul 16:51 UTC
Re: Network Down ?
« Reply #16 on: July 24, 2007, 05:32:06 PM »
Is it just me then who can't access the network data at the moment?
Re: Network Down ?
« Reply #17 on: July 24, 2007, 05:39:24 PM »
That did the trick - network back online at 17:38 UTC - although only 178 aircraft which seems a bit low.  Maybe it will build up as it collects shared data.
Re: Network Down ?
« Reply #18 on: August 05, 2007, 09:15:39 AM »
The Network appears to be down at the moment.
Sun 5 Aug 07 0915 UTC
Edit:
Still down at 10:11 UTC
Edit:
Still no network connection at 11:54 UTC :-(
Edit:
Still waiting at 14:13 UTC
« Last Edit: August 05, 2007, 02:13:50 PM by Allocator »
DaveG
Re: Network Down ?
« Reply #19 on: August 05, 2007, 02:17:40 PM »
Just so you know its not just you :)
No network here at 14:17 UTC
Cornwall, UK
Re: Network Down ?
« Reply #20 on: August 05, 2007, 02:39:11 PM »
We are investigating the issue. Up till now we had 99% uptime rate for the network. Please bear with us.
Re: Network Down ?
« Reply #21 on: August 05, 2007, 03:12:10 PM »
Thanks DaveG, I did start to wonder .........
Re: Network Down ?
« Reply #22 on: August 05, 2007, 03:13:06 PM »
Thanks AirNav.  There is bound to be the odd network outage every now and then.
« Last Edit: August 05, 2007, 04:24:40 PM by Allocator »
Re: Network Down ?
« Reply #23 on: August 05, 2007, 04:17:13 PM »
Should be working now. These things unfortunately do happen.
If you notice an issue such as this please email support asp and we will investigate.
Re: Network Down ?
« Reply #24 on: August 05, 2007, 04:24:25 PM »
Thanks, Network confirmed back up.
My next question was going to be who to contact if there is an outage, but you've answered that.  I'll go direct to Support next time.  I tend to post to this forum to make sure that it is the newtwork and not just me with a problem.
DaveG
Re: Network Down ?
« Reply #25 on: August 05, 2007, 04:43:43 PM »
Hmmm  Still down for me at 16:43 UTC
Cornwall, UK
Re: Network Down ?
« Reply #26 on: August 05, 2007, 04:53:03 PM »
Restart the app if you cannot connect as its definitely online
DaveG
Re: Network Down ?
« Reply #27 on: August 05, 2007, 05:07:13 PM »
okay restarting app done the trick, but why the need to restart?
Cornwall, UK
Re: Network Down ?
« Reply #28 on: August 05, 2007, 05:45:14 PM »
It should keep retrying to connect, but after certain amount of retries it gives up (such as instance where you might disconnect from the net) to save resources.
