Amazing V1.6 Screen Shot - NASA Satellite Views
Started by AirNav Development, August 05, 2008, 04:13:01 AM
Yes you can turn it on and off. There is no night view, as you say it will be pretty dark and useless :)
Steve R
Hi Airnav,
The new screenshots look amazing, good work, makes me even more pleased that I didn't buy the SBS-1.
So what we got planned for ver 1.7, lol (Only joking)
SteveR
DaveG
yep looks good, would be even better if you could undock the window and move it outside the main window onto a second screen ;)
Cornwall, UK
Tallyho
I notice on your example screen shot you have extended runway centre lines shown in white (Final approach lines).
Are these additonal outlines overlayed on the sat view, in which case can you run both sat view and outlines together on the same screen, that would be handy, so we could have all our additional information (e.g. ATC zones, danger areas, restricted areas) displayed on the Sat View?
AirNav Team
These are the standard RadarBox runways and centrelines as in the RB internal database.  You can also show outline files for airspace too just as when viewing the normal map display. You can turn them on and off as you wish.
Colours are customisable via the Preferences menu as normal, and then can be exported for later use as a Satellite colour scheme.
testmonkey
Another question regarding this new feature.
Will we be able to save images for use when viewing offlne or will it be (as I suspect) a strictly online feature?
testmonkey
AirNav Team
#21
The 2 satellite options are Download and Load.  Download saves the satellite map as a jpg file and a calibration file and then loads it for display.  The 2 files are saved in a /Satellite directory. The Load option loads an already downloaded (saved) file.
marcdeklerk
Airnav, we can't wait!! when can we get our hands on V1.6??
marcdeklerk
AIRNAV, any update on the release date? regards
Its in beta testing at the moment, we are resolving any of issues they have. Hopefully after that we will release the forum if it all goes well.
Nearly there now :)
Brisbane
Will the new version correct the freezing problems that have plaugued some of us from start. Mine runs all day OK for a couple of weeks, then starts all over again. It froze again just a few minutes ago, so had to restart.
Very frustrating!
Yes it will, however please note if its running fine for a couple of weeks and then doesn't it sounds like something has changed which has caused that.
Contact support and they will be able to help you.
Longhorn
AIR NAV RADAR BOX
BCD996XT
BCD396XT
ICOM IC-R2500
ICOM IC-R75
D130 - VHF/UHF ANTENNA-PREAMPED
75FT LONG WIRE-HF ANTENNA
