AirNav RadarBox 2009 (version 2.0) RELEASED
Started by AirNav Development, August 19, 2008, 03:12:20 PM
Climb1
Quote from: Allocator on September 03, 2008, 08:31:39 PM
Like I said in my first post "it could just be me messing up". Thanks Allocator. Its all working mighty fine now! The bizarre thing is I never used to use the =<> drop down box in the previous ANRB versions and seemed to work ok (honestly!) But obviously I wasnt using it properly. lol.
Many thanks again.
Wayne
shaun
The new version is very good,
the only thing i would change is puting changed and tracked at the end of the
interface and have status first because it would make more space for the map.
10 NM NW of EGMC
Essex
UK
Hi Showchen and welcome!
We're all hoping that the option to have the columns in whatever order we want will be in the next version.
manuel
Hello there Support and everyone on the Forum. Just installed Version 2.0
Everything is working fine but just one small problem: after the update my Radar doesn't show any logos at all despite they're all in the Logos paste in the correct location. Any ideas? Thanks in advance and thanks for the update this version is much better than Version 1.5
Quote from: manuel on September 11, 2008, 06:43:02 PM
Did you do a new full install, or did you do an upgrade?
What version of Windows are you running, XP or Vista?
The logo's can't be in the right place.  They should be in the \Data\Logos directory.
manuel
Hello. I just updated from version 1.5 to version 2.0
I'm running ANRB on Windows XP Service Pack 3. PC with 2.5GB of memory and a Centrino Duo 2Ghz system. Thanks.
John Racars
Quote from: manuel on September 11, 2008, 07:02:14 PM
Hi Manuel,
I also had some problems after upgrading from 1.5 to 2.0. AirNav Support did recommend me to install the full version 2.0. After doing that all problems where solved.
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Manuel
You could check that the logo files are in the correct place.
Don't take any notice of the directories that end with Org (Original) - these are just backup folders I've created.
manuel
Hi again. Affirmative. The logos are on the correct folder on the correct place. Maybe I'll try to leave my Radar on for the night too see what appens.
Manuel,
I suggest that you do a full install of RadarBox 2009 as it looks like the upgrade didn't work completely.
manuel
testmonkey
I had exactly the same problem Manuel and despite re-trying the upgrade several times it never fixed it. Tried the full install instead and copied over my NavData database, photos etc. from v1.5 and all worked fine. Go the full install route instead :)
testmonkey
tamás
Hello uraim beszél itt valaki magyarul??Do you speak hungary??
Sorry we don't.  Only English please on this forum.
tamás
Sorry,I'dont speak english,but we make a trial!!
