AirNav RadarBox 2009 (version 2.0) RELEASED
Started by AirNav Development, August 19, 2008, 03:12:20 PM
Your MyLog data will be empty if you installed Version 2 without doing the upgrade. Once it picks up things they are added to the filters, the filters only work on items which are actually there.
Racinghenk contact support directly. A blue screen error either means driver fault (unlikey if you have the latest version) or something else in your machine. The software itself if it gets into a tangle should not cause a restart.
DaveR
I did the upgrade, data was still in the database explorer however not in MyLog.
After uninstall and reinstall the MyLog feature works, but obviously no data. I copied the datafile previous to reinstalling, any easy way to reinstate it?
Quote from: DaveR on August 19, 2008, 05:58:34 PM
Is it just me or is anyone else having problems with MyLog?
When I open it the list is blank and even the Quick Filter Box is empty, no drop down options?
All OK here, 338 aircraft received today - about 2 hours worth of receiving.  If you click "Show All" do you get any aurcraft in the MyLog list.  My Quick Filters are fine too.
Although I've been beta testing RB2009, I did backup the beta version and did a complete new install using the link at the top of this thread.  I did however copy my old MyLog.db3 and NavData.db3 files across to the \Data directory so that I've got data from before today.
#33
Quote from: Allocator on August 19, 2008, 06:29:30 PM
Beware that you can't just copy a v1.5 database to use in v2.0.  There are new fields added.  During beta testing I did develop some SQL code to add the new fields, but that's a high risk solution!!
Just heard word from Development that in fact you can do that. RadarBox 2009 will recognise the old format and add the new columns to it :)
DaveR
Bad news is it didn't! Wonder if my data file is corrupted somehow that 2008 could live with but not 2009.
Still gives me an excuse to leave RadarBox running!
testmonkey
Quote from: DaveR on August 19, 2008, 06:38:55 PM
Could be!
I'm also having some strange issues having gone the upgrade route. My silhouettes are only showing for aircraft with a short name starting A, the airline logos are also only showing where the callsign starts A and almost no flight routes are showing. All the 'missing' items are in the correct folder or in the case of the flight numbers do exist in my routes table although it's interesting to note that my routes table has not added the new column needed for the 'date added' information.
testmonkey
Try a clean install or try the upgrade once more.
Bethsalem
Updated to RB2009 a few hours and it's running flawlessly.  Thank you to AirNav Systems for listening to users and continuing to improve on an already fantastic piece of decoding kit.
drskeptical
Downloaded the new version this afternoon. All running hot straight and normal.
Also I have just purchased a new 24" monitor. Fantastic!
Now I can have my list on the left side of the screen and the radar on the right in good size.
Excellent.
mt007
Hi friends,
can anyone help me work with ftp screenshot?
I have try it, but notnhing happen.
Thx.
Quote from: mt007 on August 19, 2008, 08:38:56 PM
Hi friends,
Thx.
How familiar are you with html code?
I've created a page on my web server and I load the FTP jpg picture to it.  I'm assuming that you have the web hosting address and passwords entered in the RB Preferences menu?  Don't forget to set the correct folder structure too in the Preferences section.
This is the code that causes the page to refresh every 60 seconds:
<meta http-equiv="refresh" content="60; URL=http://www.ruyton.demon.co.uk/html/radarbox.html">
And this is the code that shows the picture:
<td width="633" class="TextObject">
       <p style="text-align: center;">AirNav Systems Live RadarBox Screenshot - Automatically refreshed every 60 seconds</p>
       <iframe id="InlineFrame1" name="InlineFrame1" src="http://www.ruyton.demon.co.uk/radarbox/RadarBoxScreenShot.gif" width="700" height="860" frameborder="0"></iframe></td></td>
     </tr>
Please note also the screenshot is 5 minutes delayed, so it will appear 5 mins after you start the upload incase you have entered the details and wondering why it has not uploaded yet.
mt007
hi,
i know about 5 minutes delay, but my problem is configure in RB preferences.
Look: http://www.pgavirtual.com/RB/radarbox.htm
I assume you know your FTP settings. This feature is really for advanced users so just checking whether you know certain items.
If so, then the only issue is getting the root path correct
e.g /public_html/RB/ will get into a folder on FTP rather than what you may seem on the domain.com/RB/
You can find out the exact path from your website host.
