New Silhouettes
Started by RodBearden, August 19, 2008, 11:19:45 PM
I can't find a conventional one either, so I've done them both.
NF2G
The Huey silhouette is B412.bmp in the ANRB distribution files.
Another missing one - the Lancair Evolution - EVOL
#183
Hi Rod, I'm just Receiving D-EGQA a Bolkow Bo208C Junior ICAO Type JUNR  unfortunately only with a conventional Silhouette. I would be great to have it as a Photo Silhouette. Thanks in advance.
(http://www.airliners.net/photo/Bolkow-BO-208C-Junior/0960380/L/)
Well, there is another Photo Silhouette which in my opinion could deserve a Re-Do: It's the one for the Hot-Air (Fire-) Balloons: BALL
Perhaps, if you have some time you could do a new one with more than just one Balloon on white back-ground. Like this for example: http://www.zurkuhlen.de/juli2006/heissluftballon770.jpg
And just for fun this one: http://www.ballonservice.de/webblog/wp-content/uploads/2007/04/darthvader.jpg
Hi Ingo - here's the JUNR, and what do you think of these?
Sorry, Darth Vader is the wrong shape!
Hi Rod, Darth was just a little joke.
About the two others: BALL1.bmp was the one I was looking for. But BALL2 is also very nice. Well, now I would need a function which allows you to toggle between them: If it's dark outside use BALL1, if it's bright day use BALL2. But as long as this function doesn't exists I would go for BALL1. Thanks a lot again.
Regards Ingo
Hi Rod, I just noticed, that there is no photo silhouette for the Remos GX (ICAO ident GX), would be great if you do one. Her a link to a picture: http://www.stcharlesflyingservice.com/wp-content/uploads/2008/12/08-628_0722.jpg
#188
Here you go Ingo - thanks for the suggestions
Here are GX, BREZ and AS21.
Oops - the AS21 was too big - now corrected.
Time for a zip.
The last one was on 15th December 2010 in reply #100. This one contains all the photo-silhouettes posted here since then, plus, possibly one or two more (I really can't remember!)
The zip of all 500 of the photo-silhouettes is now on my downloads page here: http://rodb.gofreeserve.com/RadarBox/Downloads.htm
Evening Rod, I found three further AC Types without a photo silhouette:
1st: SSH T-131 Jungmann (BU31) ( http://www.heimatmuseum-fischamend.at/images/pf03aoearminderluftbuecker_480.jpg )
2nd: SCHLEICHER ASH-25E (AS25) ( http://www.alexander-schleicher.de/produkte/ash25/ash25_001.jpg )
3rd: SAN D-140 Mousquetaire (D140) ( http://images3.jetphotos.net/img/2/1/4/2/52915_1287478241.jpg )
#191
Here you are :-)
Oops again - sorry - AS25 was too big - now corrected.
Evening Rod, thank you for the AS25 update. I got another without a photo silhouette: Cessna 195 (C195)  http://www.airliners.net/photo/Cessna-195A/1363213/L/&sid=ed1d64d36faae35fb103f3187278720e
#193
Here it is Ingo - a C195
