New Silhouettes
Started by RodBearden, August 19, 2008, 11:19:45 PM
Jason,
It is being operated by a B738 so I would think you have it.
Hi Jason
As Alan implies, the silhouette is generated by the ICAO aircraft type which comes from the database. As long as you have the B738 silhouette in your Silhouettes folder, then the culprit must be your database entry for that particular aircraft.
The aircraft operating SWG626 is C-GKRB which I only added to the d/b yesterday so unless you have downloaded todays Navdata update it will not be showing any info including the ICAO type identifier
New one:
PIVI - Pipistrel Virus
Here's another we don't have a photo-silhouette for:
BL8 - Bellanca/American Champion Scout/(Super) Decathlon
And another:
NOMA - GAF Nomad
It's about time I did a photo silhouette for the CSeries CS100 now that it's flying. The ICAO website doesn't seem to have caught up with it yet, but Airframes has the code as BCS1, so I've done it as that. Bombardier's naming system is awfully cumbersome- apparently it's the BD-500-1A10 CS100.
CYYZGUY
AAL9707
No Silhouette showing.
Hex : A01880
Any ideas?
regards,
40" LED Monitor
40" LED Monitor
Jason,
A321 N105NN on delivery now in the d/b
It's nearly 18 months since the last photo-silhouettes zip, so here's a new one with all the ones posted since then (reply #470 on the 31st July 2012).
The zip of all the photo-silhouettes is on my downloads page here: http://rodbearden.com/RadarBox/Downloads.htm
#595
Hi Rod!
I wasn't able to find a photo silhouette for the YK52 Yakovlev Yak-52. Have I missed it?
Thanks!
No - we hadn't got it - here is one.
YK52 - Yakovlev/Bacau/Aerostar Yak-52/Yak-54
CYYZGUY
Hi Rod,
I have CFZCC
Mode-S C0423B
Aircraft type G280
No Silhouette??
regards,
40" LED Monitor
40" LED Monitor
Hi Jason
Yes - we already have a photo-silhouette for it, but not a conventional one.
SP7 - Spartan Executive
